W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Fri Jul 03, 2009 9:18 pm
Well heres a money saver for ya
The 01 (HAS TO BE 01 im pretty sure) maxima MAF sensor is the exact same MAF, but sells for less than half the price..... stupid stealerships, think it was $110 VS $400+ for the one listed for our car
Theres quite a few threads about it if you search and get the part number, youll notice orderring online from Pinnacle Nissan, that the prices are MUCH cheaper than we have at canadian dealerships, and they do actual rate shipping, no gouging.
As for throttle body sensors, I wasnt aware we had any, but if they are anything like the throttle position sensors on a honda, you simply need a voltmeter and a spare foot, the TPS (throttle position sensor) has to read a certain voltage at idle, and at wide open throttle (WOT thats my name!!! /stupid plug lol), and you simply loosen its retaining bolts and adjust it, by rotating it, until its in spec, you literally have to move it a cvnt hair to see adjustments, reading its voltage by tapping into its lead wire with your voltmeter
Id clear the codes, clean the MAF sensor and IACV body thouroughly, and see whats best from there
