MAF question
Jehangir
Car: 1992 Infiniti Q45A
Well, my MAF connector is bad. I know this because my car runs better as I jiggle the connection. But that being said. I'm not too sure what to do about it. I' ve cleaned it and bent the male ends hoping for a tighter fight but with no help. Can I buy these anywhere? If anyone can help my 92Q. I would be much appreciated
Q45tech
Don't jiggle too much or too often because this extra stress gets transferred thru the MAF pins and on to the MAF circuit board whicn can cause internal intermittents within the MAF itself. Internal solder examination and repairs is useful.
Old Q owners should all have a SPARE MAF in trunk parts box just as FPCU, ECU, TCU.......................electronic modules whose failure will stop the vehicle.
Harnesses and connectors are usually harder to swap on the side of road in a rain storm.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The MAf conector was updated in late 1994 MY. You cna order the part form Joe.
Q45tech
Read Delphi tech paper concerning old solder problems under hood
CrimsonQ
Car: Purple People Eater
Have 2 extra mafs, if ya need 1
goody90q45
Car: 1992 Infiniti Q45 (sold)
Jehangir wrote:Well, my MAF connector is bad. I know this because my car runs better as I jiggle the connection. I've cleaned it and bent the male ends hoping for a tighter fight but with no help.
It's the female pins on the connector that need to be tightened not the male pins on the MAF (I'm sure that's what you meant). Clean off the corrosion on both parts also and lube them up with dielectric grease. You can replace the plug but the easiest thing to do would be to swap in a known good MAF.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I can probably lay my hands on one. How much can ya spare? Email me at [email protected]
