reggiegsd »
https://forums.nicoclub.com/reggiegsd-u144.html
Thu Jul 03, 2003 4:55 am
After thinking about this for a while, I have a few questions/observations.
Max boost would occur at the minimum air flow rate (Max back pressure), just like any other constant speed centrifugal pump.
Minimum boost would occur at maximum air flow rate (Minimum back pressure).
If the Q motor flows 275 scfm at WOT, then the fan must flow at least this much into 0 backpressure to prevent a loss at WOT.
Wouldn't this device be most effective at the lowest RPMs where the Q needs help and would provide a decreasing boost as RPMs increase where the Q needs little or no help?
All discussions I have seen about these fans compare them to superchargers or turbo chargers. Those devices vary their speed with engine speed, either mechanically of due to increasing exhaust flow. This means higher engine speed equals higher boost. The fan works just the opposite. Constant speed with decreasing boost.
Electrical load is based on flow rate x pressure increase. Generally speaking, load will be highest at low air flow (not zero) conditions (Max Boost) and lowest at high air low (Minimum Boost). What would the electrical load be at 2500 rpm (about ~100 cfm) and 1 pound of boost? (For the technoweenies, try the power to compress air formula)
I suspect about 300 Watts or 25 amps per pound of boost at these conditions.
Maybe this thing could work at low RPMs where it would do the most good.
