First Question :
I finally got a J60 MAF ! I tried the Q45 maf and the N60, but they both didn't work. The Q45 was a Noob mistake, and the N60 was a result of listening to other people. When I got the J60 I realized it didn't come with a pigtail. Does anyone know where I can get a pigtail or just the connector ? Is there a USDM connector that would fit ?
( Q45 and J60 MAF are both for sale $50 each shipped)
My second question :
I found an inter cooler on eBay the specs sound good, but are they realistic for the type of intercooler ( same side inlet outlet).
Specs:
22.75'' x 11'' x 3" High Flow Intercooler Square High Flow Tube & Fin Design Light weight designed. Made of Aluminum. All TIG Welded 6061 Aluminum. PSi Drop under 0.2. Other Intercooler usually drop 2 Psi Some are More. Max PSI is 40 Up to 600HP Has top mounted inlet/outlets Core Size: 19.5" x 11" x 3" with 2.5" inlet/outlets
Link :
http://cgi.ebay.com/ebaymotors...a078b
Modified by opticnerv at 10:27 PM 12/3/2009
