WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Mon Jan 21, 2008 6:18 am
Sounds ok to me, watch the AFR's at idle, see if they go over rich, and crank the idle air control valve open a bit. IIRC it's turned counter clockwise to increase the RPM. You'll just need a snub nose phillips screw driver. Try for 800rpm as a goal with the engine warmed up. If it refuses to stay running you may have another problem.
Is the BOV leaking by chance?
WD
