maf problems
240wootie
Car: 1989 rb20 coupe, 2002 WRX
i finally got my rb20 started and running, much thanks to Carl H but i'm having a problem with my MAFS. it starts and runs with the MAF unplugged, but it dies when i plug it in... any ideas? i searched around, but i only found z32, q45 and other maf questions... any help would be great!
S13 240SX
Car: 93 Mazda Miata
psh join the party.. i know how u feel.. yes it sucks
i had a mafs problem when i did my swap.. cuz i used an n60 mafs and it was wired wrong.. so if you had to hard wire ur mafs re-check it again. or if you are using the stock rb mafs then it shoulds to be dead.
240wootie
yeh, its the stock rb20 mafs. dead huh? that sucks. is there any way to test it? i really dont want to buy another one. but if i have to thats all i can do huh? i thought i had a wire crossed when i extended the wires, but i dont. any body else have this problem?
240wootie
any body?
S13 240SX
Car: 93 Mazda Miata
yeah ur stock rb20 mafs is dead.
240wootie
so if my MAF is dead, is there any other MAF i can use on the stock motor without having to have the motor tuned for that MAF? How much does using a z32 affect the engine? can i use a z32 n60 MAF without having it tuned. i live about 5 hours from the nearest shop i can have it tuned at... any help would be appreciated!
S13 240SX
Car: 93 Mazda Miata
n60 works with no tune so i hear from others.. i been using an n60 with no problems...
a z32 mafs will need a tune.. n60 no.
