jpd »
https://forums.nicoclub.com/jpd-u46342.html
Fri Sep 01, 2006 8:23 am
Hi everyone,
I'm new here. I've got an 02 I35 that ahs been great up until 2 months ago, when I got the engine power loss, tcs, ses and "slip lights." My mechanic said it was the MAF and replaced it for alot of money. HE assured me over and over it was normal for them to go out, it was definitely the MAF.
Now, less than two months later, same problem. At autozone, it threw the p1102 code for MAF, and said "MAF in range but less than expected." DOes anyone know whta this means?
My mechanic's solution is to see if he can replace the new MAF under the parts warranty, and if not, order a new one. He acted like I was crazy when I asked him how he can be sure its a bad MAF. He said that that's what the code says, so that's what it is. He can't get to it until next week, so I think I'll take the car back and clean the MAF, check connector etc.
Does anyone have any suggetsions on what could be causing MAF failures like this?
Also, I've read that I can use a 2001 MAF, with slight modification. Anyojne have any luck doing that?
Thanks for any help.
