Ok Here is the situation. I am not getting a signal from my maf. I upgraded to a Cobra MAF. I checked the MAf and it is working fine. I checked the power and it is getting power I checked the power ground an it is grounded I checked the isgnal ground and it is grounded. I checked the continuity of the signal wire and it is ok. It was working fine then I was tiinkering under the hood so I disconnected the power ground to move it out of the way. When I hooked it back up the MAF would not work. Does anyone ahve any solutions or encounterd this problem before? Please help. I want to drive my car again.
91 240sx Auto TrannyNsport Turbo kit with Split Second Air/Fuel Ratio calibrator
