Locknut »
https://forums.nicoclub.com/locknut-u35423.html
Mon Dec 13, 2010 9:27 am
Car's been good for years (just the normal injector replacements)...now she's acting up. I checked fuel pressure, swapped out fpcu with a known good one, scoped and ohmed injectors, ohmed ks's, checked egr, cleaned aac and bench tested solenoid with 12v, replaced plugs (couldn't get to no. 7!!!), checked for spark from coils with spare plug....still getting rough idle and bucking under power. I suspect the MAF...or mabe a clogged injector? I disconected the MAF and tried running in fail safe...but it still seemed to run a little rough. I've ordered ECU talk so i can do a power balance...but I'm thinking if i can get a cheap used MAF....I'll try that first. I've seen some right now on ebay...for $100 bucks...sounds too good to be true....what do you guys think?
thanks guys....
just want to add...I checked the MAF connector, wiggled it around, cleaned it, tightened it....removed and cleaned maf sensor with maf cleaner...
Locknut on Mon Dec 13, 2010 6:43 pm, edited 1 time in total.
