MAF Problem
Ardietriz
I'am an owner of a Nissan Bluebird 93' model with engine type SR20 DE with chasis no. BDAU-13. I'm looking for a MASS AIR FLOW METER part my car, on the part there is a no. 22680-59J03 & AFJ-50-071. On the website there is an available part (MASS AIR FLOW METER) for the NX2.0L 93' model with engine SR20DE fuel injection same as my car engine type is it possible to buy same part with same engine type but a different Model, do you think it will work & the performance is the same.Thank'sArdietriz:(
NISTECH
the part number on a 93 Nx 2000 is 22680-53J00. that indicates they are different parts. I went through all the closest models and it appears none of them use the 22680-59Jxx airflow meter. These meters are calibrated so if one was close you could use it but none of the american products use that number.
