Maf Problem
FlukierRory
Car: 1991 240sx Hatchback
Sr20det Forged Internals
Hey guys, Ive been googling this for a while and tried everything but no luck.
So i have a s13 sr20det redtop with a z32 mac. Car was running fine before the engine was pulled for a rebuild.Put it back in and it has a rough idle and bogs and dies. I unplugged the maf and the idle gets better. So i figured bad maf and bought a new one. Still no luck, same idle problem, any ideas? Thanks for any help guys
FlukierRory
I also forgot to plug the knock sensor in, although im not sure what effect that would have
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
Check for damaged MAF wiring.
Nikita240
Car: SR20DET S13 240sx Hatch
What ECU are you running it with? Stock ECU is incompatible with the Z32 MAF.
S-chassis life
Car: S14 Zenki KA24
S14 Kouki S14 SR20
if it was running fine with stock ECU then is was already Tuned... maybe it might just need another tune. try using a Stock S13 SR MAF and see what happens. also like what the previous post said maybe wires got damaged or your Z32 MAF might have gone bad or dirty
