hungryjoseph »
https://forums.nicoclub.com/hungryjoseph-u50257.html
Wed Jun 02, 2010 1:08 pm
need to know which wires on the s14 sr kouki maf are ground/power/signal. the outside wires are green and white/red.the middle wire is red. i almost want to say the white/red one is the signal wire and the red one is the 12v and the green one is the ground since the red and green are wrapped together in the grey sleeve going to the ecu. but i want to make sure
car has symptoms of gay maf (<3k revving, running like the special olympics)
the wiring from the maf to the ecu looks fine, it just randomly crapped out while I was timing it. i'm going to install my q45 maf since it's just sitting here. I found the wires for that, just can't find info on the kouki maf... unless i am just a retard at google. if i am forgive me
