e_classic »
https://forums.nicoclub.com/e-classic-u11261.html
Thu Nov 13, 2003 11:06 am
Problem: ONLY when on throttle between 1 ½ to 3000 rpm range engine breaks up (like its stumbling)
History:
Just bought a 95 240sx with about 116 thousand miles. Car was totally stock and had been sitting for about 1 ½ years.
I immediately did a minor tune up; changed oil, oil filter, air filter, and spark plugs.
Jocked it stock for about 1 ½ months until, I got a great deal on a S-AFC used from a friend. Car ran great, my only change to the stock settings was starting @ 3 thousand RPMs and higher I gradually leaned the engine out to 10% more air.
Problem started about one week after putting in the apexi controller.
Check engine light pops up.
Checked code on ECU. Reads CODE 12
I read a post on here somewhere to check the MAF wires at the intake. It reads 1.38 volts steady on my output wire @ idle and raises with my throttle. Is that my problem right there??? The post that I read said the output should read 0.5 volts @ idle. Positive and negative are straight (12volts steady).
Any help with this is greatly appreciated.
PS
All variables have been eliminated…such as
All connections to the ECU from the S-AFC I have check and double checked.
S-AFC was working great in my friends car….it went straight from his car to mine in under an hour.
Just to be sure a have disconnected the S-AFC and rerouted the MAF wire (if you’ve installed this controller you know what I am talking about.)
Still have same problem without S-AFC plugged in.
Thanks E
