ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri Sep 19, 2003 8:29 pm
I now have a genuine SR maf opposed to the KA SOHC maf. My car runs. It did the same thing yours did with the SOHC maf. I just installed my SR maf like 5 minutes ago and now she idles away. It is kind of rough but an idle is an idle. The difference in the two mafs as I checked them in my room with a car battery was as follows:
KA SOHC maf (from stanza, ht accidently sent wrong maf which caused the idle problem). 0.6v-0.68v
SR maf (ht replaced it with overnite shipping and everything free of charge). 0.85v-0.95v
These test were at about 72 degrees in my house without blowing into them, just a stand still signal test. Try this, block off most of the main intake hole for the maf so that more of the air goes through the heat element (use tape to cover like half of the maf opposite side of the element). If it starts off, then the Maf is the culprit. If so, try cleaning the elements with something without breaking them. What is happening could possibly be a low air reading causing the ecu to spit less fuel, when more air is actually being sucked in.
