480sx »
https://forums.nicoclub.com/480sx-u50548.html
Mon May 07, 2007 4:58 pm
I think i know whats going on here. Your front clip came complete with an upgraded Maf, but not the piggyback controller that was used to run it. You need a piggyback ecu system or you need to buy a stock Maf with pigtail.
I would suggest getting an SAFC2 with your upgraded turbo. Its the most widely used and user friendly tuning device EVER(lmao, but so true) Pick one up used from our classifieds or ebay. The install itself is pretty easy, im sure you can find a bunch of info on it by searching for Sr SAFC.
Also, for the time being, i would run stock levels of boost(7-8), and run the SAFC as simply a translator between your upgraded MAF and your stock ECU. With that turbo you could easily blow up your SR if you turn up the boost. Go over to the SR20DET forum and read all the stickys, im sure they will answer most every question you will have. Later on, you can either get a professional dyno tune from a shop, or get a wideband O2 sensor and tune it yourself.
Hope this helps and good luck man, your gona love your SR they are a freaken blast.
