maf problem.
nb07bcar
I think I have a problem. What is everybodys air flow % on their safc2 at idel. Mine is at 3 and it used to be at .8%. I think I might have a bad air mass meter. Also my car at a certian throtel point is going lean . does anyone have an idea? its around 10% throttel open. just in the area it takes to keep my car cruzing down the road. It might be the air mass meter?????
Modified by nb07bcar at 5:22 PM 10/31/2005
Craving4Boost
Car: 91 240sx fastback
mine is .2% at idle. are you using stock injectors? is your safc2 set up for a standard 4cyl. with a 240 stock maf?
nb07bcar
I'm using 42lb injectors. stock maf. and I am at 5in 5 out. I don't know if its the maf. When I got the car it was hit in the front and alot of the air box plastic went throught hte maf. I found it all the way into the valves. So I don't know if that broke it.
