Dmnitsadean wrote:or is it that one part before the intake tubeing the one were the throttle body is at? help me understand thanx....DeAn
the only sensor that is there would be your tps(throttle position sensor)
if for some reason he cleaned that part off which i dont think that he did due to the fact that i think you have to remove your throttle body to get it off he might have not put it back where it need to be set at. but i think that he broke the filament.
sorry for double posting but what exactly does your car do. when you say it runs bad there are about 10000 reasons why. but if it doenst go past 3000 rpm's or it runs bad at a certain rpm's then there is a better chance that i might be able to help you out.
