nismo1003 wrote:MY MAF is before the turbo and a Blitz DD BOV in the cold pipe, so it cause to backfire sometime, however, i want to run a hose from the BOV to my MAF , but the problem is that my MAF is attach to the Air filter directly so I can put the recurclate hose before the MAF , but I could put it After , I was just wondering if that works? I know it sounds werid , but believe it or not, my friend had a 1.8T GTX engine , the STock MAF is before the turbo and the stock recirculate hose RUN after the MAF ? do yo know anything about that?
Dude, the reason your buddies GTX has the stock recirculating hose routed after the MAF is because that's the only way it will work correctly.
Think about it. Air goes through the filter, gets metered by the MAF, through the turbo, through the intercooler, then to the throttle body. If you BOV is after the MAF and it vents to the air, it will run rich, because the MAF has already metered that air. When it gets released into the atmosphere, not as much air gets to the throttle body, so the engine runs rich.
With a recirculating valve, the air gets diverted back in before the turbo, but after the MAF. This keeps the air in the system so the engine doesn't run rich. If you routed the recirculated air back before the MAF, that air would get metered twice. If you did this, your car would actually run lean between shifts. That's bad. You don't want to blow your engine the first time you shift.
Look at the picture above. That's exactly how you should route your recirculating hose.
