Lev_96_240sx »
https://forums.nicoclub.com/lev-96-240sx-u82573.html
Fri Jan 15, 2010 11:01 am
Look I don't know what else you want me to tell you. You have a larger turbo with a larger outlet, larger hot pipe, etc, this all leads to a higher volume of air being required to bring the pressure up to 10psi. If you try to run the t28 piping on a t04 you are choking the turbo and getting no benefit from it.
What does this all mean? Well you have increased the volume of the air chamber in between the turbo outlet and the throttle body, meaning that it now takes more air to get up to pressure, just like the semi vs road bike inner tube example. So while your boost gauge won't show a difference and the waste gate is set to 10psi, you are getting more cfm or air moving through the system.
Hope that clears it up.
