Brian VT »
https://forums.nicoclub.com/brian-vt-u268405.html
Tue Jun 26, 2018 6:18 am
My daughter is 4 hrs drive from me.
She has recently had a couple instances where the car shuts down without warning and she has to fight the steering and brakes to get it stopped safely. It restarts fine each time. Kinda scary though.
She recently changed her air filter and 5 of her 6 spark plugs (good girl) but it has happened (quit) again since then.
I'm going there this weekend. I plan to bring a new crank position sensor and MAF cleaner.
A new CPS is cheap. A new MAF is not, so I'm hoping a cleaning helps.
Which would you bet is the problem/culprit? Would you buy a new MAF before finding out if the CPS is the culprit?
Or do you suspect a totally different culprit?
