WestTxSR20Tuner wrote:My car had idle issues. When I would unplug the MAF it purred like a kitten. So I barrowed my friends MAF and it the car still went crazy when I hooked up his MAF. It was possible this MAF was no good either so I ordered an intake and bought a used Z32 MAF off of EBAY. When I hook up the MAF the car idles crazy and the throttle ony responds every 5th rev or so. I have to keep feathering the gas pedal to keep the car going. The throttle just ignors my feathering. Every 5th rev or so it picks up. When I take the MAF out of the intake and set it to the side of the intake it idles OK. I have been following the FSM and it has me replacing all these hoses which I have done. My wirring was done by Wirring Specialties.
Should I try buying another Z32 MAF?
Does my ECU have to be tunned for a Z32 to make it idle right?
Can I have the MAF and knock sensor tunned out instead of replacing the MAF because I want to get my ECU tunned any ways.
Modified by WestTxSR20Tuner at 9:53 AM 3/28/2009
I may be wrong, (someone please correct me if I am) but it could be your TPS (throttle positioning censor). My old beretta had a bad tps and for some odd reason changing the maf would temporarily fix the problem... It had the exact same symptoms as you also... Constantly rolling my right foot off the brake and onto the gas at the same time to keep it running while sitting on hills at redlights... (fun memories.... lol)
