jmhalder »
https://forums.nicoclub.com/jmhalder-u26798.html
Sat Jul 21, 2007 9:50 am
you have to realize that flow is NOT linear with voltage, so if 2 volts=200cfm, 4 volts will NOT equal 400 cfm, in fact it will probably be much more. take a look at actual ECU VQ map for any of these MAF's, at the high end, you'll move more air while the voltage doesnt raise quite so fast... although that does sound a little high.
