MAF load
jmt1030
Hey everyone,
I'm trying to get my project up and running. The car turns on but it's running very rich. I'm using Nismotronic.
What should MAF load be at with the car off, but the key turned to the on position? Mine is currently reading at 33.
Does that sound about right?
PapaSmurf2k3
Site Admin
What MAF are you running?
...and 33 what? If its 33 volts, then uhh, that's some kind of impressive anomaly. I was thinking it should be somewhere around .3-.5 volts, but you can double check in the factory service manual.
www.nicoclub.com/fsm
Do you have an adjustable fuel pressure regulator? Do you have larger fuel injectors? Do you know what the tune is for? Can you adjust the tune yourself? Does it run rich over the entire RPM range, or just at idle?
