MAF-less SR questions
blackieblack
Car: 240sx s13
i am running d-jetro power fc on my sr redtop. my question is how do i setup my vacuum lines? i have a t off at the fpr which is where the map sensor gets its signal from. which is what i was told by apex to do. whoever is running on map gimme some pointers on how to set things up. much appreciated.
burnin240sx
you could also use the port near the bottom of the throttle body. but done use the one on the TB. you need a good source on the manifold after the TB.
blackieblack
Car: 240sx s13
bump
