Ok it holds a really strong idle, and by mechanical timing do you mean cams and belt right? if so its on right all the marks lined up correctly wen changing the belt. I'm not sure about the vac though, its not really like a back fire i could get a video if it would help just as soon as i give it gas it starts to pop almost like detonation if u no what that sounds like it does it gets a lot worse when you actually drive it i haven't really touched the gas at all im trying to avoid hurting it. As far as the plugs go i actually just replaced them today to get that out of the way.
ca18detgabby wrote:where and when does it "pop and hesitate"
what does it do at idle?
are you getting proper vac?
how is your mechanical timing looking?
back fire?
have you pulled your plugs and checked them?
