pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Fri Dec 03, 2004 3:44 pm
you definately need a diagram because the ecu needs to see the ground input from the maf so tat wire needs t obe run properly. the reason your car runs ok when it is cold is because the ecu is in ope loop and runs off of the tps only. be sure all wiring and connections are good to the maf and to the knock sensor.
