400whps13coupe wrote:turbulant air throws the maf off period. mafs read air both ways in and out thats y they recommend running your bov back into intake if throttle body is shut the released from bov travels back through the maf in reverse letting the engine know to cut the fuel for that amount of air.
False.
They recommend recircing BOV's because they release air AFTER it's been measured by the MAF which throws off your air fuel ratio. Plumbing it back into the intake pipe after the MAF keeps the same amount of air in the system.
You're correct in saying that the MAF reads airflow in either direction but it can't distinguish between them. Which is why turbulent flow is bad for MAF readings: Regardless of which direction the flow is going the ecu still reads it as airflow INTO the engine and adjusts fuel accordingly.
