Amybirds »
https://forums.nicoclub.com/amybirds-u43849.html
Sun Jul 23, 2006 1:26 pm
Ok, I did the ECM Inspection for everything that didn't require the engine to be running (which seemed to be most of it...).
Here's what I tested & the results:
Canister control solenoid valve: okIgnition switch: okPower souce for sensors: okPower supply: okThrottle position signal: .442 V (ok)Battery: ok
ECCS relay: ok when engine is off, but unable to test it with engine running, or just turned off from running. (noted that it was .888 volts when the ignition switch is "on", but the manual didn't give specs for that).
Inhibitor switch: ok in P, not able able to try N or other gears.
Fuel pump relay: ignition switch "on" (first 5 seconds): was 1.9V (ok) ignition switch "on" (after 5 seconds): should be 0V but instead it remained 1.9
Fuel pump voltage control: ignition switch "on" (first 5 seconds): was 1.9V (ok) ignition switch "on" (after 5 seconds): should be 0V but instead ut remained 1.9
Unfortunately, since I can't start the car, I can't test the items that I'd really like to know more about: MAF, EGRC solenoid valve, ECCS relay (with engine running)...
So, what I conclude is that the two fuel pump items that are supposed to stop getting a charge after about 5 seconds of turning it to "on" are still getting their "startup" voltage. Which I'm guessing means that something somewhere is not doing it's job of telling it to stop. Or the ECU is fried and not telling it to stop?
I checked for any sounds of relays clicking in the trunk/fuel pump area since the results above tell me there's something going wrong with the fuel pump electically: there are no clicking noises, but you can sort of hear the pump hmmm-hmmm-ing on and off in time with the clicking of the ECCS relay & EGRC valve, and there is a faint liquid-running sound that is also (even fainter) in the engine compartment when the key is turned to "on".
Now what. Should I test the EGRC solenoid valve? The page in the manual says to check for air passage continuity. What does that mean? Like, feel for air coming through? And when they show to run a line with a fuse from the battery to the item, I'm assuming that fuse-wire is something I can acquire at Radio Shack?
And is there anything I should know before I go and try to disconnect the EGRC valve to test it -- like how to get the darn plastic cover that's protecting it off without disconnecting EVERYTHING around it. Or any screws that are adjustment screws that I need to NOT touch?
Thanks!!-Amy :-)
