mech_E »
https://forums.nicoclub.com/mech-e-u62247.html
Mon Sep 27, 2010 6:00 pm
Hello,
So I have been doing a lot of research, and with research I have found much confusion, so was hoping somebody could straighten me out here. I just did the s14 sr20det swap, and my car is running very rich and sputters a bit. When the engine warms up it tends to want to die, by idling around 250 rpm and sputtering and shaking. After a lot of research, I think I may have narrowed it down to the MAF. I have the "black" WC ecu and the rectangle MAF. A buddy came by with the same swap and we traded out MAF, but he had the round connector. So I rigged it up to work on my car. When I started the car, it just died. So I think I have a MAF sensor problem along with another issue (maybe IACV? or dirty plugs from running rich). But my concern is to what MAF sensor to get. The harness originally came with the round connector but I took that off and put the square connector on, thinking it was the same output. Am I wrong in doing this. Do they both give different signals to where one wont make the car run correctly?
Thanks for the help,
Nicholas
