MAF Cleaning
ArcherV20
Car: 1995 240SX
I did a few searches and didn't turn much up. I did a google search and found an article on doing it to a Ford. I'm not sure if it's the same process or if there are any specifec tips you guys could share with me when cleaning the MAF - I am lead to believe it's a cause to the problem I'm having with my car. So if you guys know a quick simple way to clean it, let me know thanks!
Quick & simple, here ya go:
Remove MAF.Spray liberally with brake cleaner (NOT carb cleaner).Reinstall.
ArcherV20
Car: 1995 240SX
Thanks Hitman, if I could bother you further, I heard it was a bad idea to use brake cleaner? Is it just hearsay - or should I spring for some electrical cleaning ****.
