MAF and SAFC Help
StoneBoy
Car: Nissan S14 KA24DE-T
Hey I just installed my JWT ECU with a Z32 MAF and what's happening is that I'm getting a constant signal of 5 volts from the MAF so the SAFC is reading 100% airflow all the time even when the car is only on the "on" position. Any ideas of what is causing this and how I can resolve it? Also whats the sensor settings that I'm supposed to use on the SAFC, my ECU is tuned to treat the Z32 MAF as stock, I have it set to sensor number 2 in 2 out and sensor cal 1 in 1 out?
180fan
Car: 89 fastback
check over your maf settings
blackieblack
Car: 240sx s13
btw....... i dont mean to thread jack but. my guy has a vefc he just bought and since i have an sr with safc i was going to help him out until i realized that. man that vafc was super crazy. all these crazy settings. i told him his stuff was gonna blow up. just buy hondata. yeah my $0.02. sorry. im glad i have an sr. thank you sr god.
480sx
Car: 1996 Pearl White 240sx
Your SAFC settings are wrong. For the number, set it 2 in 5 out if you are running a KA24 or 2 in 6 out if your running a SR. Apexi's webpage has a bunch of downloadable PDF files that help you with the SAFC and their other apps. Hope this helps.
480sx
Err, nvm on that last post then.. Didnt read well enough, if your aftermarket ECU is set to read the z32 maf as stock then your safc settings should be fine. Check the wiring to the MAF, make sure you got that right, might have a wire crossed.
