Understand the CAS is the master clock for ecu. The cylinder must fire in a narrow range say 15-40 degrees before TDC depending on load [air density in cylinder] and injectors must open as soon as the exhaust valve is closed.
The ECU compares its counting of the 360 pulses with the 2 ZEROS [wider slots in both 90 degree and 1 degree circuits which use seperate electronics for redundantcy] that denote the starting point.
We have seen a few CAS that after 10 years get dirty inside and may obscure a few of the 1 degree slots causing a lack of pulse but the ecu compares both pulse trains.
At 1800 rpm thats 30 rps or 360 x 30= 10,800 pulse per second and 120 of the broad 90 degree pulses to check against.
Now being off time 2-5 degrees won't have much effect except at WOT or cruise [gas mileage].
http://www.picotech.com/auto/w....html
New designs have both a crank and cam angle sensor as a triple check.
The point is if you see both waveforms and there are few or no drops outs, the idle will be fine as the problems tend to show a very high rpms.
Since the CAS is adjustable the EXACTNESS of setting it to 15 degrees in CRITICALLY IMPORTANT! Every degree your are OFF with the timing light translates to the ecu being OFF 1 degree.
Chain stretch retards the CAS [and the cams since the CAS is attached to the drivers exhausr cam].
A perfectionist would check timing every 2 years [30k], hardly ever done so the CAS creeps towards retard by about a degree every 50k.
The important thing is that the sprark fire in the correct position of the piston [the cam positions just play with air amounts and are only significant at high rpms above the 5500 rpm range].
Peak torque is achieved when 66-70% of the fuel is burned at a 15-17 degree AFTER TDC.........function of rod leverage angle vs peak pressure..........too soon burning and the pistion is driven straight down wearing out the crank bearings fast, too late and the pressure has dissapated.
You read the MAF voltage at idle [1.2 volts], cruise [1.8] and WOT 4.0-4.4] at 6500 rpm.
Really impossible to diagnose these items without a Consult [ precision recording data monitors] or just simple substitution with brand new parts...........on EBAY you can just be buying other people's problems........they may or may not know.
