Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Oct 14, 2004 8:09 am
The 90-93 have one type of output connect and later models [94-96] have a different one.
The voltage output vs air flow graph are the same since the engine is the same size. Never tried making a adapter between the two models.
A few tenths of a volt difference can translate to quite a bit of injector time variation.......especially above 4,000 RPM WOT.At cruise the O2 will self correct the MAF over a +- 15% range, not so at WOT.
