made it to the track again
shockload
Car: 240
first pass, 22psi and the sun was still up and the track was warm.second pass , 25ish psi it really came on but couldnt get traction . it was dark by then and cold with 200 street tire cars peeling off the stickiness.all passes were made with 35psi in the tires. i also made the camber on the rear tires straight when it squats down off the line.
Modified by shockload at 9:50 AM 10/7/2006
Jookmasta
man if those images aren't the testimony to HOW IMPORTANT those 60ft. times are, i dont know what is...................congrats on the first pass but traction is now your new goal..............seems like u got more than enough power lol. hence what ur sig says.....
shockload
Car: 240
i let the air pressure in the tires down to 18 psi and tested it once , helps make first gear pull harder for sure. maybe i will run it on tuesday, the track is gonna be closed really soon though.
nissanfanatic
Car: 1992 Nissan 240sx SE
Jookmasta wrote:man if those images aren't the testimony to HOW IMPORTANT those 60ft. times are, i dont know what is...................congrats on the first pass but traction is now your new goal..............seems like u got more than enough power lol. hence what ur sig says.....
Nah, I think I'm still the king of tractionless runs.LoL
Jookmasta
no ur not the king, ur the definition OF tractionless.................lol. any ya, droppin the air pressure in them tires should definitely help you out.
1WheelWonder
Car: 1991 Nissan 240sx
Wow those are good times, what's the fastest stateside sohc?
klattr1
Car: GT42R powered S14/KA
there have been 8 and 9 sec SOHC's...
just not in a S-chassis
chandler
Car: 91 civic hb & 96 S14
man I definately need to get my s14 back on the road now, im jelous
xekushnr
Car: '90 Nissan 240SX Hatch
yeah, some new rubber and/or lower tire pressure should help your traction issues. reguardless, thats not too bad of a 60' time.
GlacierFreeze
Car: '97 240sx (the tortise)
Dang you're trapping 115+ mph. Get some drag radials man.
nissanfanatic
1.8 60' is actually pretty good. I don't think he needs anything other than more seat time..
shockload
Car: 240
i can gain a little on 60 foot but most of the spinning is after the 60 foot evn with drag radials. with lower pressure in the tires now it hooks like a champ and with the added grip in first i can spike second a lot harder due to more momentum off of first gear. on the street it will pretty much billow smoke off the tires but also gets moving at the same time. should be able to pull a lil more fuel on upper rpms to make it pull a lil longer. i must say this setup is a little different but with higher boost it seems like its waking up a bit.
WDRacing
Sweetness, I'll agree with Cory on this one. Seat time is where you'll make up the most time. As long as you keep the 60' times under 2 that is. I've only had a couple 1.6 60' times, its just hard to nail them, so a consistent under 2 is key. Grabbin gears at the right time and quickly is going to take practice, its a good thing practice is wicked fun huh.
Good to see you're running so well bro.
WD
nissanfanatic
Even most stock Evos do right under 2.0, so yea, I agree that a sub 2.0 60' will net you accurate ETs for a street/strip car.
Second gear is most prone to spinning right next to actual launch. You'll just have to play around with that... Maybe try a second gear launch..
nissanfanatic
You pick up as much as I do in the second 1/8 mile tho. 32mph...
shockload
Car: 240
yeah and 4th gear wheelspin is a ***** too.
