I have a mitutoyo caliper and a few centech ones....
The Mitutoyo is nice, it reads the same as the centech ones. Plus I don't feel bad using the centech ones to scribe lines
Occasional use stuff, I really wouldn't sweat using HF/centech stuff... I have used them plenty and they have never really caused problems or proved to be inaccurate. I have seen more error from technique then from using centech stuff tbh.
This is working in thousands, or even half thousandths... any further then that and you may have issue.
(edit: I work in inches :P, what ever accuracy this is in mm.... I mean that.)
I have not used there micrometers much, but when I took engine building classes with toyota they were all cheep HF stuff and I could use pretty much what ever mic to get the same measurement, and the parts went together like the measurements were right.
Of course if you can spend more you will only get better tools
