Machine work on rb26
ATpossible
Car: 1995 Nissan 240sx
i just got the bill from a shop in town that i sent my engine to and i was wondering if it is a good price, normal, or overpriced.
list on work done...
polished crank3 angle valve jobresurfaced deckcylinder honenew ferra valvesassembled headassembled long block
total=$1840
thanks for your time
jdmser
Car: duh
It's hard to say. Are they going to stand by their work if something goes wrong in the first couple of thousand miles? Then it's definitely would be worth it. To give you a little of an idea I paid $275 to have my crankshaft collar put on(only guys in town that would touch it), $400 for a three angle valve job and the head put back together, $125 to have the head disassemble and ported by an old hotrodder, and $180 to have the seats cut, valves polished and reassembled at a machine shop owned by old hotrodders. I really all depends on the quality of the work and just because the price is high doesn't mean it's quality.
bumblebtuna
Car: rb25/26 2fotay
i'm paying $50 to have my crank magnafluxed/polished.
also getting a different shop to hone cylinders, assemble the short block (cp pistons/new bearings/studs/bolts) , and balance the entire rotating assembly for $400ish, and he may deck the block if need-be. no headwork for me
ATpossible
thanks for the info JDMSER and bumbletuna as well good info too.
ya i haven't talk to him about any warranty but i would settle for not having one sense he was suppose to check and make sure everything was within clearances and tolerances and he put it together so i expect something.
so far it still sounds like my is on the high side
anyone else have input or experience/prices? please keep them coming.
Stealth-Z
Car: 1991 300ZX
Adjusting the shims on the RB26 head is time consuming. Did it need valve guides?All the little things add up quick.
ATpossible
well i told him to check everything...and everything being the whole head and block no externals parts like turbo etc...
after the check he said the only things i needed were new rings and bearings and he also got new valves.
so i bought oem ringscalico race bearingsferra valves
