M95 ground
Danbam
Car: Infiniti G37x AWD
Does anyone knows where I can find the m95 ground location 2010 Infiniti g37x
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It will be on the steering crossmember behind the glove box. It may be a PITA to access even with the glove box removed, because they're usually bolted to the top of the crossmember. See PG-96:
https://www.nicoclub.com/service-manual ... 0%2FPG.pdf
Danbam
Thank you, honestly I kind of figured it was that one but I greatly appreciate your assurances as always helpful be safe!
VStar650CL
Technical Expert
:dblthumb:
