Mine acted similar before I reflashed the ECU and TCU at work and then Uprev tuned it. Response got even better after I cleaned the cabon out of my intake ports and valves. Mine still has a delay when you downshift though. Most of the time it will be coasting along with an ulocked torque converter, when you first get on it, it locks, bogs then downshifts a couple of gears and GOES. I usually just drive in Sport mode and Paddle shift to keep it shifting when amd where I want it to. Now at 20-25 mph even in 2nd gear I tend to break the tires loose.knelson wrote:Dallas. And it is warm out, but not THAT warm. Temperature doesn't effect what's happening.
It's always between 15-30mph, feels like 2nd-3rd gear.
It's always during upshifting. It just delays for a crazy long time before responding to pedal pressure. Then it jumps.
No way this is how it's designed to perform. It's just started doing this.
I just duplicated this about 10 times in a row. It is the torque converter coasting unlong unlocked and whem you step on the throttle, it locks shortly after. It seems that they tend to keep it locked up as much as possible.Snake31 wrote:I tried to make a video of my slippage but this is hard to do while driving. I will have someone help me next time. The video can be seen at: https://youtu.be/msQLqxVFJr8
The RPMs spike for a moment then the transmission engages and the RPMs drop down. This is in manual shift mode in fourth gear.
