EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Fri Jan 15, 2021 9:08 am
A few answers in no particular order:
1. Stop leak products could work. It depends on where the leak is and how large it is. I prefer to not use them on my vehicles.
2. Yes, you can R&R a steering rack. Way easier for those of us with lifts at home. Lol
Remember to get an alignment afterwards. Well, the car might just let you know by a generous display of dash cluster lights.
3. The reservoir in itself doesn't hold that much fluid. The piping holds a lot too.
I have seen a power steering leak masked for a while because the inner tie rod end boot was holding fluid and it wouldn't drip on the garage floor.
4. If the pump runs dry, you'll hear PS noises like groaning, whining, pumping marbles etc. And of course you'll have increased steering effort.
As far as pumps go, the PS pump seems pretty hardy to improper lubrication - add fluid and go, but it's definitely a system I wouldn't risk running dry or even low for too long.
Btw, the worst case I've ever heard of was the ECU being taken out by PS system neglect.
