walt1227 wrote: ↑Thu Jul 26, 2018 7:34 am
Ilya wrote: ↑Thu Jul 26, 2018 7:01 am
I'm not sure of the brands but where is the knock sensor on this car? Is that the little 'pinging' or 'tink tink tink' I hear sometimes when I give throttle?
What's the OEM part number? Advance Auto has one and it's $265...and we need two. Holy crap that's expensive!
EDIT: NVM, found it: 22060-1HC0A. That's the first time I've EVER seen an aftermarket part cost more than the OEM part lol.
IIya now you got me wondering if that is what I be hearing when I get on mine. It is ticking noise that happens with the more throttle you give it. The motor is quiet so it is not the lifters like I hear on my neighbors Mustang. I thought it was my flex pipes from the custom exhaust I have on my car with a possible leak but Vic said I would see smoot somewhere if it was a leak since these cars do smoot up pretty good in the tailpipes. Where are those knock sensors located? I may change them and see if that makes it go away. It did not start doing it until sometime last year during the summer.
Yeah, I hear my ticking usually when I'm giving partial throttle on a road that creates more load...like a hill or something. Not always...but I've been hearing it for probably a year or two. It's not constant, just happens sometimes. I've tried all sorts of different gas and it doesn't seem to matter. I've tried Mobil 93, Sunoco 93, Cumberland Farms 93...all of those are 10% ethanol. Lately I've switched to Stewart's gas which is 91, but non-ethanol so 100% gasoline. Still happens.
SnowNYC1 wrote: ↑Thu Jul 26, 2018 8:17 am
Unfortunately because it's a Infiniti they make our lives harder
the knock sensors are located on the top of the block, you have to take of the entire intake manifold. Oh and the gaskets for the manifold are NOT reusable. So those gotta be changed too! $5 a pop from Infiniti. And we need 8..
Yeah, I found that in the FSM when I went looking. That's beyond stupid. That's almost as stupid as making the front catalytic converters part of the manifolds. F'in idiots man. My 1999 Maxima had the knock sensor on the outside of the block, easily accessed. 10 minute job, if that. Replacing the catalytic converter on that Maxima was a 30 minute job. Here you have to pull the motor and pay thousands. Headlight bulb swap? Maxima...5 minutes. Infiniti? 1hr job...gotta lift the car, remove wheel, remove wheel liner plastics, etc. Ballast swap? Gotta drop the bumper.
This is easily a $1k job at the dealer. $500 for the sensors, $400 for labor and $100 in misc parts. I swear they design these cars like this on purpose to keep their dealership mechanics in business. It's getting harder and harder to work on your own car.
If you do do this, PLEASE DO A HOW TO!!!!!! lol
