vp007 wrote:I have been complaining to the dealer about a hesitation with my car for over a year and they always tell me yeah it's the transmission and that's the way they all are. The problem is more tied to the traction control than the transmission - has anyone else experienced something like this?
I am now driving the car in sport mode and I press the button to turn off the traction control each time I drive the car - this makes some improvement.
The button gives me a yellow light of the car with wavy lines under its wheels.
The hesitation is more like a complete lack of power although sometimes the car surges after a brief pause.
I can't reproduce it on demand, but most of the time this happens it is after hard breaking, a sharp turn, going over a crest in the road while turning or when hitting a pothole while accelerating. Pretty much if the car is off balance or spins a tire it shifts the car into a lower gear and the acceleration is almost zero.
The car is a 2011 M56X. The mechanics always say wow this car has so much power. How can you complain about the acceleration??
This has been very frustrating. Anyone?
Hmmm... do you know if there's any way to discern between the symptoms of a bad torque convert and simply needing a software update? Are there one or two distinct symptoms/occurrences that indicate the torque converter needs replacing?IlyaKol wrote:Moving this thread to the right section (it was missed when the Y51 forum was created).
That being said, my 2011 that I just picked up had the torque converter replaced by the previous owner under warranty as they were describing something similar to the dealer.
I can read through the service history of my car again when I get home and see if they added any other notes.NoTalentLoser wrote:Hmmm... do you know if there's any way to discern between the symptoms of a bad torque convert and simply needing a software update? Are there one or two distinct symptoms/occurrences that indicate the torque converter needs replacing?IlyaKol wrote:Moving this thread to the right section (it was missed when the Y51 forum was created).
I would expect issues at a complete stop in drive - vibration, lurching, surging, if the TC is malfunctioning, and perhaps a lag between hitting the gas and leaving the stopped position.NoTalentLoser wrote:Hmmm... do you know if there's any way to discern between the symptoms of a bad torque convert and simply needing a software update? Are there one or two distinct symptoms/occurrences that indicate the torque converter needs replacing?IlyaKol wrote:Moving this thread to the right section (it was missed when the Y51 forum was created).
Hmmm... in that case, I'm wondering if I may be experiencing an issue with the TC. I notice sometimes that when I'm either accelerating from a stop or slowing to a stop, the car will sometimes do three "mini-lurches," where it seems like it goes back-and-forth for a second or two. It's hard to explain, but it's more than just a vibration... more like a back-and-forth shake, maybe?veery wrote: I would expect issues at a complete stop in drive - vibration, lurching, surging, if the TC is malfunctioning, and perhaps a lag between hitting the gas and leaving the stopped position.
Was this free of charge?racerbeav wrote:In the event anyone else is having the same issues, I took my M56 to the dealer, and thankfully I connected with a mechanic that knew his stuff. This is a known issue with the engine and transmission computer firmware. He applied the updates and, low and behold, I have my hot-rod sedan back!!
In the event you need to visit the dealer and ask about the TSB, my work order says: "Reprogrammed TCM and ECM per ITB12-021B". Hope this helps someone out there!
