Ilya wrote: ↑Tue Sep 09, 2025 9:22 am
Yeah that's definitely still original. Any pointers on where it is or the part number?
It's not too bad. Here's some info on my 3.7 / AWD, yours is a bit different.
I replaced the rear transmission mount (11320 in diagram) and bought some new bolts just in case the rust monster got uppity.
The rough job, from memory, was:
- Raise front on ramps / jack stands
- Remove nuts (08918-3401A in diagram) holding bottom of mount to crossmember (11340 in diagram)
- Support the back end of the transmission with a jack and/or jackstand
- Remove bolts holding crossmember to frame (11520AA in diagram), drop crossmember
- Unbolt/remove/replace mount
- Reinstall crossmember (follow the torque sequence in the FSM)
- Replace nuts holding mount to crossmember
- Done
On a whim I looked up your 2011 M56x and it looks a little bit more complex:
The part number for your rear mount looks like 11320-1CA0A but obviously double check that.
Looks like a few more dampers (not shown in that diagram but in a couple of others), beefier crossmember, and different mount attachment method, but I don't see anything that would make it terribly more difficult than the 3.7.
I will say that the rear mount on the 5.6 AWD looks quite a bit beefier than the one from my 3.7 AWD, so my experience of a collapsed mount may not apply to you. If nothing else it's easy to pull a few bolts and check for evidence of the transmission hitting the crossmember or something similar.
