asafinar wrote: ↑Sun Jul 12, 2020 2:51 am
I have M56x 2011 I have the same issue with srarting up the car. Its 50/50. It can start from the first attempt and it can start from the 10th attempt.
At first I thought it was the the key fob discharged battery causing this problem, but then I replaced it, but no change. Still have that issue.
My thought is that the low voltage of the car's main battery can cause the starter not to react.
My car keeps 11.9 volts while on parking. Even when I drive it shows 11.9 or 12 volts.
But a lot of people say its not normal and this could be an issue.
Guys please share your experience if you had this type of problem solved
Good thinking.
While I currently dont have any issues I recall buying a new ( to me) Xterra.
As part of my "making my used car near perfect" routine I bought a new gel type battery for it.
I originally had wanted to buy an Odyssey gel type but they dindt have one in stock..
So I went with their house-brand, made for this chain.. I dont remember the brand anymore..
Few months later had starting issue in mild winter weather.
Never thought it was the battery since it was near new..
But a check at a local dealer showed that indeed it was..
Then I remembered that when starting even from day 1 the start was never as immediate and positive as I was used to from my other cars even when battery was new.
The moral of this story: .. I strongly suspect my battery was bad from day One when I i bought it at the auto parts store ...and it finally showed up as a noticable issue later.
I now have a slightly oversize Bosch made-in-Germany Battery in the car.
