M56 with the 37 engine
Thestack686
Car: Infiniti M56x
Nissan Altima
Hey guys I have a 56 with a damaged engine it's expensive to get a replacement.. had anyone successfully or know if it's possible to drop down to the v6 ??? Yes I know I'll lose power etc but at this point I could care less ..
PapaSmurf2k3
Site Admin
Anything is possible with enough money :)
I imagine you'll have to replace the trans and driveshaft with it, as well as the ECU and wiring harnesses.
PalmerWMD
Car: 2004 350Z
The parts cost for engine may be cheaper.
But the labor cost will be significant higher sadly, you may also need to buy extra parts down in the powertrain.
BUt theoretically it would certainly be possible.
PS: What happened with your engine?
PS:2: What kind of engine prices did you find?
Thestack686
Car: Infiniti M56x
Nissan Altima
PalmerWMD wrote:
Sat Oct 24, 2020 10:26 am
It was an auction car that I believe the engine was damaged purposely as an insurance job .. so it's my problem currently. Engines are 3500- 5000 dollar range plus installation
PalmerWMD
Car: 2004 350Z
Well we know 2 things:
- The 3.7L has enough power for your car and
- It fits into the enigne bay
But I am concerned about the ECU/TCU and even some hard parts down in the powertrain.
if you had a wrecked donor car with salvageable parts it may be ok ( still a lot of labor costs though)
And you'll get a lot more uncertainty..
It may be better to bite the bullet and get a used V8 ...
Thestack686
Car: Infiniti M56x
Nissan Altima
PalmerWMD wrote:
Tue Oct 27, 2020 6:30 am
I also want to know if a Nissan Titan can be used i found a very affordable engine on ebay
Yoda's Master
Car: 2012 M56
2009 370z
Why don't you try the 400 red sport motor (VR30DDTT). It should fit since it replaced the 3.7 on the Q50
PapaSmurf2k3
Site Admin
The Titan V8 has some different tuning and sensors than the Infiniti does. I wouldn't recommend it. You MIGHT be able to use it if you swap over the intake and exhaust manifolds, but you'd be in uncharted waters.
The VR30 would be a pretty big tear up, but yeah it could be done. You'd be looking at big money though.
Thestack686
Car: Infiniti M56x
Nissan Altima
PapaSmurf2k3 wrote:
Wed Oct 28, 2020 8:22 pm
Well if I was gonna drop big money I'd might as well get a q70 engine or a ls lol ...
PapaSmurf2k3
Site Admin
Exactly.
