Missed the brand earlier but I agree. I use TYC cabin filters, etc. and they are pretty great.VStar650CL wrote: ↑Mon Sep 06, 2021 8:20 amMy experiences with TYC parts in general have been very positive.
I went the cheap route and ordered the $80 starter. Hopefully it will last. Thanks for the input.Ilya wrote: ↑Wed Sep 08, 2021 10:05 amMissed the brand earlier but I agree. I use TYC cabin filters, etc. and they are pretty great.VStar650CL wrote: ↑Mon Sep 06, 2021 8:20 amMy experiences with TYC parts in general have been very positive.
I got my starter for $90 including shipping and the gaskets for $50. I also bought the gaskets on both sides of the throttle body as well.Boatfixer27 wrote: ↑Fri Sep 10, 2021 11:49 amMy starter is likely going bad also, only 85k on car. I was at the dealership yesterday getting the driveshaft recall done and mentioned the starting issue and they quoted me $1198.21!!! Of course they could not replicate the problem, it happened when again at home after I looked at the new driveshaft.
My 2 cents, after looking into what is involved, is it worth going with the lowest price starter?
Has anyone found a better source for the intake gaskets? eBay has some at $21 each, and others at $40+ Which adds up for 8!
I saw them pictured on EdBwoy’s video, and they don’t look like anything special? (Worth 40]
ibc wrote: ↑Sun Oct 17, 2021 7:03 pmWhat symptoms made you want to change the starter motor? How do you diagnose starter problems?
My m56 has intermittent starting problems, but they mostly seem more like battery drain, since the car starts fine if I keep a charger plugged in. On errands, I'm scared that it won't start. Often takes 6+ attempts. We always carry a spare battery charger now.
How hard is it to change a starter motor on M56? I've done it on older cars, but I think this v8 needs its heads pulled for this job? I'm an average DIY car fixer. Is it doable?
The numbers can be quite confusing.
Hello maybe you can help me. I replaced the starter in my m56 and now car starts perfectly, but It threw two codes immediately. P0031 and p1148.EdBwoy wrote: ↑Mon Nov 01, 2021 7:40 pmThe numbers can be quite confusing.
When I bought mine, I ordered part # A4035-1MC0A and the kit came with 8 gaskets. It costs in the neighborhood of $40.
It replaced the old part number 14035-1MC0A and if you entered this old number, most search results will return A40351MC0A instead. I know that infinitipartsdeal confusingly lists 140351MC0A as a single gasket, costing $6.25
Apparently you can also buy all 8 in one kit as part # A4035-1CA0A, but that costs around $110.
If I were in your position, I'd just order a single unit of A4035-1MC0A and you should be fine. These days I buy most of my items from Infiniti of Orland Parks.
Can't imagine a starter replacement has much to do with the emissions/O2 circuit...how many miles on your car? Might just be a crazy coincidence.mr56 wrote: ↑Sun Sep 11, 2022 5:04 pmHello maybe you can help me. I replaced the starter in my m56 and now car starts perfectly, but It threw two codes immediately. P0031 and p1148.EdBwoy wrote: ↑Mon Nov 01, 2021 7:40 pm
I would check the electrical connection for the A/F sensor wire, assuming you disconnected that while trying to get the wiring harness off the intake manifold.
i bought that same one also. still starts strong after 2 years. The price goes up and down. It was around $80 a few months ago.madmanpauly wrote: ↑Fri Sep 29, 2023 7:21 amI used this one and have no regrets. Much cheaper than OEM.
https://www.amazon.com/gp/product/B079W ... slink=true
