M56 Oil Cooler
DFW2011M56S
Car: 2011 M56S
So I talked with Rod at Z1 Motorsports today about fitting my M56S with an oil cooler. After talking with him I feel it will not be a problem using their kit for the 370Z/G37 on the M56. Most likely going to get their largest 34 row Setrab core and get the thermostatic adapter to keep from overcooling the oil in cold weather. It will bot be a cheap upgrade by any means but should help ensure my car never again goes into limp/reduced power mode.
Ilya
Yeah this thing becomes a pig when it's hot...will probably help it quite a bit.
Altered
Car: 2013 Infiniti M37x
I have a Stillen 25 row I'm not using if anyone is interested.
C3P
Car: 06 Frontier CC 4wd 6 speed
11 Armada 4wd
15 Q70S 5.6
Did you get around to doing this? Thinking about adding a trans cooler as well.
Yoda's Master
Car: 2012 M56
2009 370z
The hoses are going to be way too long since the oil filter isn't in the same spot.
