M56 not starting
Chase56s
Car: ???? Infiniti M56 S
Can someone help car wasn’t starting , changed oil cleaned battery terminals , got car started not it shuts off again. Obd2 codes P0345 and P0087 any ideas
These are the codes
Yoda's Master
Car: 2012 M56
2009 370z
try double check your battery terminals are tight.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The P0087 is probably an artifact of low voltage causing the lift pump to spin up too slowly, starving the HP fuel pump. So Yoda is right, check your connections including the grounds. The P0345 is a different story, it's a "hard code" for a flatlined Bank2 cam sensor and probably responsible for your no-start. Try disconnecting the Bank1 sensor. Most Nissan products will start and run on the crank sensor alone if both cam sensors are bad, but will no-start if only one cam sensor is bad. Killing the good sensor may at least get it running and confirm you have a bad sensor on B2.
Chase56s
I’m gonna look into that it threw p0345 bank 2 camshaft sensor and p0087 fuel rail/ low pressure
Chase56s
I’m gonna change bank 2 camshaft sensor and go from there
Chase56s
I cleaned and tightened battery terminals
biggie
Checked the battery itself? The 5.6 has a habit of killing batteries due to the smart alternator setup.
Chase56s
Installed a new battery same
Chase56s
I got my guy j@-?? From infiniti coming on Monday so hopefully I’ll have an update
Yoda's Master
Car: 2012 M56
2009 370z
biggie wrote:
Fri Sep 16, 2022 11:14 am
Checked the battery itself? The 5.6 has a habit of killing batteries due to the dumb alternator setup.
*fixed* :gapteeth:
Yoda's Master
Car: 2012 M56
2009 370z
dumb question. did you remember to put oil in the motor? you were doing a bunch of things and there were no issues prior to changing the oil.
Yoda's Master
Car: 2012 M56
2009 370z
lowkey pookie, that engine sounds dry
Chase56s
It does that’s the problem , I changed the oil , new battery , cleaned connectors, what ur hearing is after oil n new battery. I got an Infiniti mechanic coming on Monday to just tell me what’s really the problem I will update . I’ll post pics to show day 1 till now I appriciate your response
Chase56s
VStar650CL wrote:
Fri Sep 16, 2022 3:45 am
…..I’m not doing the work but supposedly got a new camshaft sensor update later
Chase56s
Not doing the work but new camshaft sensor was ordered , will update I got infiniti mechanic coming Monday , he works at Infiniti in my area . Hope I can help the next guy like y’all help me I appreciate all the input
VStar650CL
Technical Expert
Yoda's Master wrote:
Fri Sep 16, 2022 8:15 pm
If the engine was dry the cam would be moving but not the phasers, so the OP would be getting IVT codes P0011/P0014 and not a flatline sensor code.
