Long Story:
I recently changed my upstream O2 sensors because I noticed they may not be reporting correctly. All other sensors that can be logged via my cheaper android scan-tool have been checked and they all look normal. I thought this fixed the problem during an idle only log, but it came back during a subsequent drive.
So today, I was checking my camshaft sensors with my scan tool to see if they were reading correctly. I noticed that the Exhaust Camshaft sensors were not reporting the same values throughout the RPM range and at idle, Bank 1 sensor was up and down from -0.5 to 0° whereas Bank 2 sensor was steady at 0°. I even switched the the intake sensors to exhaust to see if that would make a difference and there was no change in either intake or exhaust timing readings. So I moved over to my ignition timing and started driving around, it looked okay, my base timing is retarded by about 3° from what it should be at idle.
I've made a few changes in the past few mths (long tube intake, larger exhaust and gutted primary cats) but the issue has been around prior to these. However it's more noticeable since I now have an audible exhaust note and I can hear something changing in the exhaust as the engine retards down to -7°. It feels as though the engine suddenly gets thrown some huge load at it or as if the accelerator pedal stops working for a brief moment, then starts working again. I can't explain it for find anyone else with a similar story....
Now, there's no codes other than a P0300 that came a couple weeks ago, but hasn't come back. I cleaned and tested the bank 1 vvt solenoid - it was spotless and very clean. I wasn't able to get the bank 2 side out because the alternator is in the way, so I left it as is figuring if one was fine, the other would be too.
Short Story:
Car is modified but not yet tuned. Problem has persisted before any mods.
No Codes
Cars timing retards itself in lower gears, then goes back to normal - then repeats it all again until I get into a higher RPM or Gear (6th or higher)
The noticeable Timing retard doesn't happen in 5th at around 45+ mph, but will happen if I am in the 4th/5th rpm range and under 45mph or so
Camshaft Sensors seem normal
I've done all the relearns and resets you can think of.
Any thoughts? Before I dig into the car to test the knock sensors - I had already brought this to the dealer and they thought it was normal but updated my ECM and TCM anyway $$. This ain't normal at all.
