M56 DIY engine cover refurb?
Pakitullanc
Car: 2012 Infiniti M56 S
Should I high heat spray paint the silver section or vinyl wrap? Lots of different opinions, hydrodrip and wrap, degrease, sand and spray and a lot of other way. Who has done a DIY and what product was used and results? Pics would be great.
Thanks!
Reason: Revise title
Ilya
Hydrodip, high heat painted or power coating is probably the best options. I can't see vinyl lasting long in the engine heat.
Pakitullanc
I think I am going with paint. Hydrodip is above my expertise. Vinyl you are right, may not last. I guess use cleaner to clean, sanding block to scuff wipe clean and spray. See how it comes out.
jethbon
Car: 2014 Nissan Pathfinder
+1 on painting. Just prep the surface really well.
