1. I am not the original owner, I believe the vehicle was a lease turn in.EdBwoy wrote: ↑Sun Dec 31, 2017 8:22 pmWow! I feel like the ghosts of M45s past are here to haunt us, lol.
I am glad you got a brand new engine with no hassle. It's usually about $17k, labor included.
3 questions I'm curious about if you don't mind:
- Are you the original owner of the car?
- Any idea what grade of oil the service dept was using?
- Had you had the timing chain recall done on your engine?
He probably has elite because that warranty you mention has a time (or mileage) limit.
Wow I also bought my '12 M56x off of a lease in Sept '15. Mine had 52k miles at the time. I have 85k now with no issues so far. Like yours, my car was maintained at the dealership, this one in NY. They used the bulk 5W30 Nissan oil (whatever that is) when they performed oil changes. Not sure if it's mineral based or synthetic. Since I've had the car I've always used Mobil 1 5W30, except for two oil changes where I tried the Mobil 1 0W40. With that said, these cars do use oil, so there's really no way to know if the original owner (yours and mine) thought to check the dipstick between the oil changes. It's possible that they didn't, and some damage could've occurred beforehand.adeedpb wrote: ↑Mon Jan 01, 2018 11:44 am1. I am not the original owner, I believe the vehicle was a lease turn in.
2. Dealership was using 5w30 Pennzoil I believe. In my final oil change I performed myself before the bearing went out I used Mobil 1 10w30.
3. Timing chain recall had been performed prior to this problem, maybe 5k miles before this issue.
Under the timing chain recall, you qualified for a new engine if your oil jet hole didn't spec out. They inserted a go-no go gauge into the hole to check it.EdBwoy wrote: ↑Mon Jan 01, 2018 10:54 pmOK, thanks for your response adeedpb.
Way back when, I was concerned as to what exactly qualified people for a new engine during the recall:
link to post, but I suppose it's just bad/ good luck of the draw on your part.
I'd say the failure rates for these engines are pretty low; and hey, percentages exist for a reason. Your engine might have been the 0.001% defect
I understand that. My concern was that the tolerances allowed by the go/no go gauge might be "looser" than those of a factory assembled engine.
